Solved: CodeTyphon 1.50 Lazarus IDE Ctrl+click 15 years 8 months ago #551
  • Konstantinos Papadoulas
  • Konstantinos Papadoulas's Avatar Topic Author
  • Thank you received: 19
I recently downloaded the latest CodeTyphon 1.50
I am soooo happy with this product that i cannot miss a single version :) Relly great work you guys...
So, trying to update some of my programs i realized that from within the source editor it is
not possible to ctrl+click on freepascal include files to open them. e.g. Registry, ShlObj, SysUtils, Windows etc.
The include files from the lazarus dir are opening ok e.g. Forms, Dialogs etc.
These files DO exist in the FreePascal directory (C:\pp) under their respective subdirectories but the IDE
cannot "see" them.
I forgot to mention that this is happening only in the x32 lazarus enviroment. I need to cross check
again the setting between the x32 and x64.
Finally i found a solution to that one:
1) Deleted ALL files from C:\lazarus\bin32\settings\
2) Copied ALL files from C:\CodeTyphon\binSettings\win32\lazarus\
3) Restarted lazarus x32 IDE and Ctrl+Click is working on FreePascal Units.
4) Restored my preferences from within the IDE.
I love CodeTyphon!!!
Kostas
Re: Solved: CodeTyphon 1.50 Lazarus IDE Ctrl+click 15 years 8 months ago #552
ver 1.50 has a lot of work
We have a lot of ideas for next release,
GIS engine, more code for Titan Script library etc...
"Have fun", this is our "Moto"
