TAChart and Steema TeeChart Pro 5 years 9 months ago #15566
  • Konstantin
  • Konstantin's Avatar Topic Author
Hi Sternas !
We use ported version of TeeChart Pro for our software with CodeTyphon for build Linux-version. This component package contain TChart and TChartListBox  duplicated with lz_TAChart package.
Can you rename components TChart  and TChartListBox  and TChartComboBox from   lz_TAChart package   or  make optional installation ?
Also how about port TBCEditor component to CodeTyphon (github.com/errorcalc/TBCEditor) ?
Best regards Timofeev Konstantin, lead developer of SimInTech project (simintech.ru)
TAChart and Steema TeeChart Pro 5 years 9 months ago #15567
a) We can't rename TChart , TChartListBox  and TChartComboBox of   lz_TAChart package, it's an old package and a lot app use this pkg.
b) You can remove lz_TAChart pkg from your CT installation,  look here
c) We will try to port TBCEditor to CT, but no promise.
The following user(s) said Thank You: Konstantin
TAChart and Steema TeeChart Pro 5 years 9 months ago #15583
  • Konstantin
I manual recompile lz_TAChart package and unselect  "register component" checkbox in conflict units. Because if i full remove lz_TAChart - it make conflict into other components.
TAChart and Steema TeeChart Pro 5 years 9 months ago #15584
  • Konstantin
Do you need sources of TeeChart Pro for CT ? (send to my e-mail pls)
TAChart and Steema TeeChart Pro 5 years 9 months ago #15585
NO, if you are NOT the TeeChart Pro Owner.
YES, if you are the TeeChart Pro Owner.
