Configure For Multi Arch 6 years 11 months ago #14196
  • Chad Adams
  • Chad Adams's Avatar Topic Author
I have CT installed on Linux Mint. It works fine. I want to also compile on Win32/64.
How do you exactly install the Win32/64 libraries or whatever it needs?
I cant find much information on this.
Thanks,
-Nugax
Configure For Multi Arch 6 years 11 months ago #14197
  • Chad Adams
I continue to get errors like this:
Stage 5: Copy Files and Units
[ERROR]: FPC64 Cross Element x86_64-win64 Param:xxxx NOT Exists
Configure For Multi Arch 6 years 11 months ago #14198
Configure For Multi Arch 6 years 11 months ago #14200
  • Chad Adams
Thanks. What are the tool chains and os libs for?
Sternas Stefanos wrote: Try this tutorial
Configure For Multi Arch 6 years 11 months ago #14201
Start from here
Configure For Multi Arch 6 years 11 months ago #14202
  • Chad Adams
So I installed the cross builds and set the compiler targets, but the LCL Widget Type is grayed out.
I cant select it to change it.
Configure For Multi Arch 6 years 11 months ago #14203
  • Chad Adams
Also,
In my IDE, I see a Linux icon in top right, with 64 under it. On windows, its a Win icon. I assume that stands for the current OS?
Its not to swtich between build arch right?
Configure For Multi Arch 6 years 11 months ago #14204
"MultiArch" (info) and "CrossBuild" (info) Software Technologies are NOT the same.
1) "MultiArch" is the ability of CodeTyphon to exists Typhon32 and Typhon64 on the same PC (CPU-OS-Platform) (sample 1) (sample 2)
2) "CrossBuild" is the ability of CodeTyphon to build native app from Host OS (Linux in you case) to Target OS (Windows in you case).
Please follow this tutorial to crossbuild app from Linux OS to Windows OS
