Cross compiling problem 7 years 3 months ago #13582
  • William
I followed the instructions at www.pilotlogic.com/sitejoom/index.php/wiki?id=222
to build a simple android program.
If I compile with CodeTyphon32, I get this error:
Compile with CodeTyphon32
Error: Compiler "C:\codetyphon\fp(\fpc32\bin\i386—win32\fpc.exe" does not support target arm-android
If I compile with CodeTyphon64, I get this error:
Compile with CodeTyphon64
Linking C:\CodeTyphonProjects\Basichm\project1
c:\codetyphon\fpc\fpc64\bin\)<86_64-win64\arm-android-ld.exe: error: C:\CodeTyphonProjects\Basichm\link.res:350:8: syntax error, unexpected STRING
c:\c0detyphon\fpc\fpc64\bin\x86_64-win64\arm-android-Id.exe: fatal error: unable to parse script file C:\CodeTyphonProjects\BasicPgm\link.res
projectl.ppr(B,0) Error: Error while linking
link.res:350:8 = INSERT BEFORE .data1
Any help / suggestions appreciated.
Cross compiling problem 7 years 3 months ago #13583
For Typhon32 you must first build FPC32 cross-Element arm-android
please follow these steps www.pilotlogic.com/sitejoom/index.php/wiki?id=222
and please give us more info
your OS, RAM, CT ver, etc
Cross compiling problem 7 years 3 months ago #13585
  • William
System Description:
Operating System Microsoft Windows 7 Pro 64-Bit
Manufacturer Dell Inc.
Model OptiPlex 980
Number of Processors 4
Processor Description Intel(R) Core(TM) i5 CPU 660 @ 3.33GHz
Total Memory 8192MB
I had build FPC32 cross-Element arm-android for 64, but not for 32.
It is compiling ok now in Typhon32.
Last edit: by William.
Cross compiling problem 7 years 3 months ago #13587
  • William
Can someone tell me how I can package my executable into an APK so I can install it on my phone to test it?
Cross compiling problem 7 years 3 months ago #13588
CodeTyphon don't support apk.* files build.
ark file is a simple zip file and you can open it with applications like 7zip, Rar, etc
Please search on the web for a solution
PS: Your CodeTyphon version ?
Cross compiling problem 7 years 3 months ago #13589
  • William
CodeTyphon 6.80.
I am not familiar with running an android app that wasn't installed. I can load my CodeTyphon android app on my phone, but I don't know how to execute it. It tries to open it with text browsers only.
