Strip and UPX tools 7 years 3 months ago #13572
  • William
How do you add the Strip and UPX tool menu items to CodeTyphon Tools menu?
Last edit: by William.
Strip and UPX tools 7 years 3 months ago #13573
CTCenter has both, Strip and UPX tools
Do you want to add these tools and to Typhon IDE Tools menu ?
Strip and UPX tools 7 years 3 months ago #13574
  • William
Yes, I want to add these tools and to Typhon IDE Tools menu. I had to upgrade and they are not there as in my last 6.60 installation.
Strip and UPX tools 7 years 3 months ago #13575
All ds_* Typhon Packages are IDE extensions
you can start form here
Strip and UPX tools 7 years 3 months ago #13576
  • William
This is what I actually wanted. I didn't remember how to do it. This explains how to get the Strip an UPX menu items into the CodeTyphon Tools menu.
lazplanet.blogspot.com/2013/03/how-to-re...le-size-of-your.html
This also brings my executables down in size much more than when I try to use the CTCenter.
An example:
Origional 96.3
Strip -> 9.1
UPX -> 2.5
