CTC not installed 7 years 9 months ago #13057
  • Francesco Salvi
  • Francesco Salvi's Avatar Topic Author
Hello all!
I'm using CT version 6.7 on Windows 10 64, with a non-administrator user.
Installation has been made by running the batch file with administrator privileges (a collegue entered the password for me).
The IDE worked properly until I've made something wrong with packages (maybe). Now it doesn't even start due to an access violation error.
I've already tried to remove the offending package from the configuration files, but CT still shows the same error and refuses to start.
Maybe I should rebuild the IDE using CTC, but it seems not to have been installed.
Do I have to reinstall CT from scratch or is there something quicker to peform? Is there a command-line way to rebuild without administrator privileges?
Is there some already-compiled Windows CTC I can download?
If more info are useful, ask me.
Thanks, regards.
CTC not installed 7 years 9 months ago #13059
we provide only Typhon IDE Sources.
For non-administrator user my suggestion
is to restore "User Settings":
1) Go to
C:\Users\YOURUSERNAME\AppData\Roaming\typhon64\ or
C:\Users\YOURUSERNAME\AppData\Roaming\typhon32\
and delete ALL files
2) Copy ALL files from
C:\codetyphon\binSettings\settings\x86_64-win64-win32\styphon\ or
C:\codetyphon\binSettings\settings\i386-win32-win32\styphon\
to
If that NOT work you can " Remove and Build Typhon IDE" from CTCenter but with administrator privileges user
CTC not installed 7 years 9 months ago #13060
  • Francesco Salvi
Many thanks. I'm going to try this as soon as possible and will report to you. I cannot do this now: will do tomorrow.
Thanks again
CTC not installed 7 years 9 months ago #13062
  • Francesco Salvi
Great! Worked perfectly at the very first attempt with standard user having no admin privileges. I'm going to keep this solution for future reference too.
Thanks again, have a nice day
F
CTC not installed 7 years 9 months ago #13063
Have fun Sir
