Installation's failure. 8 years 7 months ago #11624
  • Giorgos
  • Giorgos's Avatar Topic Author
Hi guys! :)
I tried to install CT at Debian Jessie (oldstable) x64, only to get this error:
>./install.sh
             CodeTyphon Studio
            Version 6.40 (GEN 6)
   Installation for: Linux-Solaris-FreeBSD-MacOS
-----ERROR------ ERROR ----ERROR--------------
Current user can NOT run the sudo command
To correct this problem:
1) Install sudo
2) Add current user to sudo list
   with root privileges
I have sudo installed and in working state.
Any hints? B)
Installation's failure. 8 years 7 months ago #11625
  • zeljko
  • zeljko's Avatar
  • Thank you received: 38
Maybe this helps:
sudo nano /etc/sudoers
www.pilotlogic.com/sitejoom/index.php/13...s/548-ct-on-debian-9
Installation's failure. 8 years 7 months ago #11626
  • Giorgos
THANKS Zeljko!!! ;)
I missed the guide.
I followed the described steps until the end and I choose to build the KDE5 IDE.
However there's no related menu entry.
Ehm...how can I launch the just built IDE?
There's no Run Typhon64 IDE or related entry.
I got no error messages, but I think the installation failed.
Installation's failure. 8 years 6 months ago #11627
Did you install CodeTyphon OK ?
Installation's failure. 8 years 6 months ago #11628
  • Giorgos
Yes. Everything seems it went right.
No error messages received.
Installation's failure. 8 years 6 months ago #11629
So
-Open CodeTyphon Center
--Set platform to KDE5 (menu CodeTyphon // Settings)
--Install System Libraries (menu Host PC // Install System Libraries)
--Build TyphonIDE (menu Typhon-IDE // Remove and Build ALL)
Like this
CTCenter will buld Typhon-IDE for QT5 as Host Platform
Always you don't need to build TyphonIDE forQT5 to build app for QT5
You can build app for QT5 with Typhon IDE build for GTK2 or QT4
Typhon for QT4 ==> app for QT4, QT5, GTK2 , FpGUI etc (all supported platform targets)
or
Typhon for QT5 ==> app for QT4, QT5, GTK2 , FpGUI etc (all supported platform targets)
or
Typhon for GTK2 ==> app for QT4, QT5, GTK2 , FpGUI etc (all supported platform targets)
Debian is one of our LAB reference OS
we install and build CT on Debian 5 times per day (at least)
Installation's failure. 8 years 6 months ago #11630
  • Giorgos
1) I retried with QT4, but installation also failed.
At the end of a long process it write an error message "Sorry...", but it closed the console immediately, so I couldn't read it on it's entity.
2) I've no doubt that CT installs flawlessly on Debian but at which Debian? :)
I'm on Jessie (oldstable) and on top of that, I've disabled the SystemD monstrosity.
So, Jessie without SystemD is a quite different beast than Stretch.
There's no guarantee that a piece of software which works on one will also work on the other.
I'll give up CT for the time being and I'll be back when I'll get my hands on a more up to date system (than Jessie).
THANKS AGAIN for all your help!!!
Bye! :)
G.
