Build of Small IDE fails because fpcbootstrap.exe cannot be found 8 years 11 months ago #11183
  • Dan Statham
  • Dan Statham's Avatar Topic Author
I am a CT newbe. I have had various Lazarus & FPC installs on my computer but I have since deleted all folders with those files.
I can install the CTC but I cannot build the IDEs because fpcbootstrap.exe cannot be found.
There must be a config or ini file somewhere that CTC can find. Any ideas what file?
Thanks...Dan'l
Build of Small IDE fails because fpcbootstrap.exe cannot be found 8 years 11 months ago #11184
FPC doesn't have such file
Please
-open CTCenter after installation
-try to build FPC
-Save CTCenter Log File more info
-Attach here the CTCenter Log File (zip first)
Your OS ?
Your CT Version ?
