Problem downloading the toochain for Raspberry 8 years 11 months ago #11156
  • Angelo Mangiaracina
  • Angelo Mangiaracina's Avatar Topic Author
Hi, I installed on my ubuntu 14.04 the multiarch and then build fpc and codetyphon. this step seems to be compleated succeffully.
Then I follwed the buid for raspberry wiki.
I downloaded the win32-linux-arm-raspberryPi.7z
CTCenter 6.30
for x86_64-linux-gtk2
Start Action at 2-12-17 22:10:13
[INFO]: CodeTyphon Download Engine settings
2
xxxx2
x86_64-linux
alldownload.sh
xxxx5
xxxx6
[INFO]: Unzip files, please wait...
[INFO]: Exract lin64-arm-linux--RapberryPi.7z file...
/usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr)
/usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr)
[INFO]: Exract lin64-arm-linux--RapberryPi2.7z file...
[INFO]: Exract lin64-arm-linux--RapberryPi3.7z file...
[INFO]: Exract lin64-arm-linux.7z file...
Terminate Action at 2-12-17 22:10:13
Total time: 00:00:00.216
ExitCode : 0
and then downloaded the toolchain
CTCenter 6.30
Start Action at 2-12-17 22:11:35
2
xxxx2
x86_64-linux
alldownload.sh
xxxx5
xxxx6
[INFO]: Exract arm-linux-pi.7z file...
[INFO]: Exract arm-linux-Raspbian.7z file...
[INFO]: Exract arm-linux-Raspbian2.7z file...
[INFO]: Exract arm-linux-Raspbian3.7z file...
Terminate Action at 2-12-17 22:11:35
Total time: 00:00:00.212
ExitCode : 0
But after this both of them are not listed in local items and also in the menu for cross-build in fpc32 and 64
Problem downloading the toochain for Raspberry 8 years 11 months ago #11158
we fount the problem
the auto generated from CTC srcipt, use p7zip from /usr/local/codetyphon/binBase
and not OS p7zip
Please wait LAB CT 6.4 release (soon...)
As temporary solution just replace CT /usr/local/codetyphon/binBase/xxx-xxx/p7zip
with OS p7zip (NOT with the link file but the original p7zip file)
Problem downloading the toochain for Raspberry 8 years 11 months ago #11159
Thank you very much. Solved
