CT 5.90 reset 10 years 5 days ago #10276
  • gulyone
  • gulyone's Avatar Topic Author
  • Thank you received: 6
New behavior or little bug?
windows 7 64 bits intel I3/i55 dual core +xt Sandy Bridge 4 threads 2350MHz, 4GB ram +2GB graphics
when I rebuild optimized IDE from inside the IDE, 32bits or 64bits IDE, all is fine and the executable is Ok
BUT
when the build process is over, each time, the IDE 32/64 bits closes and do NOT start again. I must then launch it again manually.
That is not a big deal, but I am wondering what happens, and if it happens to somebody else
n.b. I verified the checkbox in IDE rebuild command that states I want to restart automatically if IDE build process passed... but it acts like ignoring it
CT 5.90 reset 10 years 5 days ago #10277
we will check this
