WINDOWS 7 INSTALLATION ADMIN RIGHTS PROBLEM 11 years 1 month ago #8186
  • Antonio Trueba Vargas
  • Antonio Trueba Vargas's Avatar Topic Author
HELLO! CAN ANYONE HELP ME, I'VE BEEN TRYING TO INSTALL CT BUT COULDNT MAKE MY COMPUTER CHECK MY ADMIN RIGHT.
IVE BEEN FOLLOWING THE RIGHT PROCESS OF INSTALATION, SO I DONT KNOW WHATS WRONG...
NO MATTER WHAT I DO IT ALWAYS SHOWS USER HAS NO ADMINISTRATOR PRIVILEGES!
WINDOWS 7 INSTALLATION ADMIN RIGHTS PROBLEM 11 years 1 month ago #8187
  • BeanzMaster
  • BeanzMaster's Avatar
Check this post and do what gulyone said, it was worked for me
www.pilotlogic.com/sitejoom/index.php/fo...-failed-on-windows-7
Last edit: by BeanzMaster.
WINDOWS 7 INSTALLATION ADMIN RIGHTS PROBLEM 11 years 1 month ago #8215
Thanks! But actually didnt work... It still shows this message.
Maybe the problem is coming from the unzip, it shows some files that are corrupted.
Have you any idea of what is happening?
WINDOWS 7 INSTALLATION ADMIN RIGHTS PROBLEM 11 years 1 month ago #8217
give us more info
Win7 ver etc
you can remove Admin Check from install.bat
REM Check for user with Administrator privileges
NET SESSION >nul 2>&1
IF %ERRORLEVEL% EQU 0 (
GOTO GO_execute
) ELSE (
ECHO.
ECHO   ERROR: "User has NOT Administrator Privileges"
ECHO   Please, run this script with Administrator Privileges
ECHO   Installation Aborted...
ECHO.
Pause
GOTO GO_END
and try again
WINDOWS 7 INSTALLATION ADMIN RIGHTS PROBLEM 11 years 1 month ago #8246
My System is Windows 7 Professional
AMD A6-4400M APU With Radeon(tm) HDGraphics 2.7 GHz.
I've been looking around and the mistake appears to be on the unzipping part.
I've unzip it with 7-zip and Winrar, and it always shows the error message displayed ont the attached image, and ive tried downloading it many times.
What could it be?
WINDOWS 7 INSTALLATION ADMIN RIGHTS PROBLEM 11 years 1 month ago #8247
my suggestion is to check your OS and 7zip installation
if you can't unzip a simple zip file the a problem exists.
Some questions :
-from where did you download CodeTyphonIns.zip ?
-did you try to unzip CodeTyphonIns.zip to other PC ?
WINDOWS 7 INSTALLATION ADMIN RIGHTS PROBLEM 11 years 1 month ago #8248
  • lestroso
  • lestroso's Avatar
Dear Sternas,
Dear Pitologic,
I cant install your software...the download is ok...i expand with 7zip and it's all ok also with win rar.... But when i run the istall.bat system give me an error WINDOWS 7 INSTALLATION ADMIN RIGHTS PROBLEM...can you fix the installer please??? i have made everything... but nothing works here!!! i have an hp intel notebook icore5 64bit windows7....4gb ram...
i have tryed also to delete the part for the admin rights...either in the install.bat and in the setup...but nothing works.....
canyou fix it?? can you help me please???
Thanks a lot in advance...
lestroso :sick:
WINDOWS 7 INSTALLATION ADMIN RIGHTS PROBLEM 11 years 1 month ago #8249
-Your Win7 ver ?
-Did you run install.bat as Administrator ?
-can you post some picture from your PC
--user page etc ?
WINDOWS 7 INSTALLATION ADMIN RIGHTS PROBLEM 11 years 1 month ago #8250
  • lestroso
  • lestroso's Avatar
Dear Sternas... I thank you a lot in advance...ok i enclose here the pictures...please i need to work with this software...because is thery powerful....thanks again
I hope will help my screen shot...
Thanks lestroso
Last edit: by lestroso.
WINDOWS 7 INSTALLATION ADMIN RIGHTS PROBLEM 11 years 1 month ago #8251
first of all your OS is Windows 7 Home Premium info
-Did you run install.bat as Administrator ? info
and my Windows 7, building (now) CodeTyphon with simple run install.sh as Administrator
WINDOWS 7 INSTALLATION ADMIN RIGHTS PROBLEM 11 years 1 month ago #8252
  • lestroso
  • lestroso's Avatar
Dear Sternas.... of course i have made all the steps in the site.....
1) i have putted the CODETYPHONINS in the root c: as requested....
2) then i have tryed everything to run the install.bat as administrator... but nothing works here...
3) i have launched from start windows...cmd.exe and seleted it to open as administrator....
4) then i tryed to type run as Admin...b ut nothing go....
5) Perhaps i missing something....can you tell me please how do you go as admin???? but in my account i'm already logged in as admin....
Why don't you make an installer more simple an installer.exe ..it could be better for every one....
i thank you a lot again..
Lestroso :sick:
WINDOWS 7 INSTALLATION ADMIN RIGHTS PROBLEM 11 years 1 month ago #8253
Sir, I thing it's your OS problem.
PS: and the end of building (now)
WINDOWS 7 INSTALLATION ADMIN RIGHTS PROBLEM 11 years 1 month ago #8254
  • lestroso
  • lestroso's Avatar
Dear sternas,
i have tryed to launch make all and rebuild.bat ...it go but i need the right sequence of script if you can...i will launch manually....
thanks lestroso
