Doubleclick problem Linux after installation 5.30 11 years 4 months ago #7679
  • Pater
  • Pater's Avatar Topic Author
Dear Community
We have a problem with CT 5.30 on Linux after the installation. After a successful 'install.sh' we did a 'Hello World' test. Simply a new project with one form and one component button 'Hello World'.
Usually on Windows7 when we double-click on 'Hello World' the source editor comes up and the cursor gets located at the correct code line.
This is not working on Linux (openSUSE 13.2 / 64 Bit).
But when I click very quickly (around six times) 'Hello world' then it jumpes to the code line. Also the right-button-menu behind a component has completely strange entries (it looks more like a default window manager menu).
To verify I did the same on a VirtalBox with Fedora 22. - Negative result.
To reproduce:
- Set up a new Linux (for example, Fedora, Mageia, openSUSE).
- Install CT 5.3.
- Create a dummy project with one form and 'Hello World' component.
- Try to double-click this button.
Any idea what could be wrong?
Thanks for your help in advance
Pater
Doubleclick problem Linux after installation 5.30 11 years 4 months ago #7680
we try to fix this problem on Lab CT ver 5.4 for GTK2 platform.
my suggestions:
don't use "Embedded Form Designer" on CT 5.3 or
use Object explorer for the same functionality
MultiOS-MultPlatform "Embedded Form Designer" is NOT so simple
The following user(s) said Thank You: Pater
Doubleclick problem Linux after installation 5.30 11 years 4 months ago #7681
  • Pater
Ok, you're right. Then I look forward to 5.40 :-)
Doubleclick problem Linux after installation 5.30 11 years 4 months ago #7682
Ver 5.40 has many fixes at "Embedded Form Designer",
and has many new Audio-Video MultiOS libraries.... ;)
