Problem upgrading to ct 5.1 12 years 2 weeks ago #6210
  • angman
  • angman's Avatar Topic Author
Hi, I have upgraded my ct 5.0 to ct 5.1 on ubuntu 12.04 64. Typhon64 run good, but ctc is not visible anymore. The process is running but don't see the main window.
Problem upgrading to ct 5.1 12 years 2 weeks ago #6211
we don't test CT on so old distributions
the oldest OS in our lab is Ubuntu 13.10
My suggestion is to reinstall CT with CodeTyphonIns.zip file or
to update your Ubuntu OS
Problem upgrading to ct 5.1 12 years 2 weeks ago #6212
  • angman
You are right, but I cannot upgrade to the 14.04 because Dell is not yet supporting it on the M4800.
Problem upgrading to ct 5.1 12 years 2 weeks ago #6213
Try to remove CT and then install again with classic zip file
-download CT CodeTyphonIns.zip
-extract CT
start installation
From Install script:
-select remove CT
-select Install CT
