Default Settings for new/upgraded Installations 12 years 8 months ago #5227
  • Dirk Jansen
  • Dirk Jansen's Avatar Topic Author
Hello
Is it possible to change the default setting for the IDE so that codefolding is enabled after installation?
And please update the code-template file lazarus.dci to the newer one from the actual Lazarus distribution. this one contains much more useful templates like "ofall", "b", "todo" and other.
At the moment I must change this settings after every update.
Dirk
Last edit: by Dirk Jansen.
Default Settings for new/upgraded Installations 12 years 8 months ago #5228
we will
The following user(s) said Thank You: Dirk Jansen
