Reporting a problem with CT 4.40 13 years 4 months ago #4262
  • Fernando P
  • Fernando P's Avatar Topic Author
Hi:
Yesterday I upgrade CT 4.30 to 4.40 and as first task I recompile my main proyect. Compilation was OK, but at runtime the program can't be executed properly. Then I download the complete CT 4.40 and made a complete new instalation. The same error is present again.
I can't find the exact line where the error ocurrs because Typhon crash before any breakpoint can be trapped near of lines I think is part of problem.
But setting breakpoint lines up. I find that problem may ocurrs when the program try to setup a child table. The parent table is opened (i believe) without problem, but maybe not because the last line before crashing try to set the PARAMS to a value (the linked field) and at that time the child table is not opened yet.
Both tables are connected using Zeos ZQuery.
As I see in changelog, Zeos was upgraded to a new version. I believe this upgrade maybe is the problem, but repeat. I'm not shure!
Then I reinstall CT 4.30 and after a compilation the program runs fine.
I'm using Typhon in Ubuntu 12.04 32bits.
Reporting a problem with CT 4.40 13 years 4 months ago #4263
first of all CT 4.40 has pl_ZeosDBO SVN 08-06-2013 Rev 2286
My suggestions:
a) use pl_ZeosDBO (SVN 06-05-2013 Rev 2224) from CT 4.30
b) use the attach pl_ZeosDBO (SVN 08-07-2013 Rev 2492) from Lab CT
Please report any problem here
Reporting a problem with CT 4.40 13 years 4 months ago #4267
  • Fernando P
Thank's for your quick answer.
I download and install CT 4.41 in another Ubuntu PC, then I rebuild the BigIDE using the SVN Zeos DBO that you kindly post here. Same result.
Then I replace Zeos with CT 4.30 version, rebuild again and the error is only moved some lines later in the code, but in this place is the same kind of operation: Assign PARAMS, to a different table.
The error is an External SIGSEGV at address 83F4E30
