BigIDE Installation error : 13 years 5 months ago #3907
  • Abdellah Al'Arief
  • Abdellah Al'Arief's Avatar Topic Author
Hello Mr Sternas,
I have downloaded CodeTyphon 4.20 today.
I installed it to my laptop: Toshiba Satellite Pro C640, Corei3, 2GB mem, Win 7 Ultimate 32 bit.
After dos prompt process, and CodeTyphon Center interface appeared, i choosed Lazarus32 BuildBigIDE menu.
After long waiting, error raised and compilation aborted. The error was:
Copyright (c) 1993-2013 by Florian Klaempfl and others
Target OS: Win32 for i386
Compiling pl_exsystem.pas
Compiling .\source\ExSystemUtils.pas
ExSystemUtils.pas(179,14) Warning: Symbol "CommandLine" is deprecated
ExSystemUtils.pas(216,14) Warning: Symbol "CommandLine" is deprecated
ExSystemUtils.pas(232,15) Fatal: Syntax error, ";" expected but "identifier ARIEF" found
Fatal: Compilation aborted
make[2]: *** [pl_exsystem.ppu] Error 1
make[2]: Leaving directory `C:/codetyphon/lazarus/components/pl_ExSystem'
make[1]: *** [bigide] Error 2
make[1]: Leaving directory `C:/codetyphon/lazarus/components'
make: *** [bigidecomponents] Error 2
[ERROR]: Lazarus32 BIG-IDE NOT Build
what must i do? can we fix this? thank you very much.
altaifa.com
BigIDE Installation error : 13 years 5 months ago #3908
  • Abdellah Al'Arief
in addition,
i tried to track this error by open ExSystemUtils.pas file in c:\codetyphon,
but i did not find "identifier ARIEF" at all in this file.
i tried to search keyword "ARIEF" on all .pas file in c:\codetyphon with NOtepad++,
but i did not find "identifier ARIEF" at all in this folder.
So i don't understand, where line of code this error raised.
for note, i shutdown all my antivirus to avoid conflict that my occur.
thanks.
altaifa.com
BigIDE Installation error : 13 years 5 months ago #3909
  • ExDatis
  • ExDatis's Avatar
I'm not sure but,before build Lazarus, build FrePascal compiler.
p.s. As admin
BigIDE Installation error : 13 years 5 months ago #3910
  • ExDatis
  • ExDatis's Avatar
BigIDE Installation error : 13 years 5 months ago #3911
  • Abdellah Al'Arief
i'll try. thanks! hope it can solve my problem.
altaifa.com
BigIDE Installation error : 13 years 5 months ago #3912
  • Abdellah Al'Arief
well, the error still occured. lazarus big ide still not installed
altaifa.com
BigIDE Installation error : 13 years 5 months ago #3913
Please rebuild BigIDE with CTCenter
zip and post the building log here
BigIDE Installation error : 13 years 5 months ago #3914
  • ExDatis
  • ExDatis's Avatar
Try Lazarus-> Remove and build Lazarus BigID(if FPC 32 ok) again
p.s. Oh, I'm sorry Mr. Sternas, I wasn't read your message and wrote almost same
Last edit: by ExDatis.
BigIDE Installation error : 13 years 5 months ago #3915
No problem Sir :)
BigIDE Installation error : 13 years 5 months ago #3919
  • Abdellah Al'Arief
I rebuild it again, and still fail.
Here all the building log:
dl.dropboxusercontent.com/u/41480422/error_big_ide.7z
altaifa.com
BigIDE Installation error : 13 years 5 months ago #3920
  • Miquel Matas
  • Miquel Matas's Avatar
  • Thank you received: 10
If I were you I'd wait few days for 4.3 release...
very promissing!
Last edit: by Miquel Matas.
BigIDE Installation error : 13 years 5 months ago #3926
  • Abdellah Al'Arief
ok. i agree with you. but maybe this report can be a consideration for future releases.
altaifa.com
BigIDE Installation error : 13 years 5 months ago #4109
  • Abdellah Al'Arief
arrrgghh.. still must wait the next release.... :( still not able to install 4.30 hope this waiting end as soon as possible.
altaifa.com
BigIDE Installation error : 13 years 5 months ago #4135
  • bjchang888
  • bjchang888's Avatar
I also encountered the same problem
BigIDE Installation error : 13 years 4 months ago #4223
  • lazzer
  • lazzer's Avatar
I also cannot Build the BigIDE. CT 4.20 on Windows XP.
Get this error.
Warning: Spoiler!
