CT Installation for Mandriva 2010.1 Spring 13 years 6 months ago #3846
  • Imam Afandi
  • Imam Afandi's Avatar Topic Author
i have got the following error :
[root@localhost CodeTyphonIns]# ./install.sh
CodeTyphon Studio
Version 4.10 (GEN IV)
Installation for Linux-Solaris-FreeBSD
0) Install CodeTyphon Studio
1) Install System Libraries
2) Exit
Select an action (press 0..2 key): 0
Copying new files
please wait...
./install.sh: line 61: sudo: command not found
./install.sh: line 62: sudo: command not found
./install.sh: line 64: sudo: command not found
./install.sh: line 65: sudo: command not found
./install.sh: line 67: cd: /usr/lib/codetyphon: No such file or directory
bash: ./setup.sh: No such file or directory
CodeTyphon Studio
2) Exit
Select an action (press 0..2 key): 1
./install.sh: line 147: sudo: command not found
./install.sh: line 148: sudo: command not found
Found: Mandriva Linux (OS ID:770)
./ln1_Install_SysLibraries.sh: line 67: ./systems/ln1_Install_SysLibraries_For_Mandriva.sh: Permission denied
please help me....
CT Installation for Mandriva 2010.1 Spring 13 years 6 months ago #3847
Sir You must add CT installation user to Sudo
here the help
