CodeTyphon 3.00 Beta1 in XP 14 years 1 month ago #2703
  • Johan
  • Johan's Avatar
Hi Sternas,
Thanks for the Update, looking forward to beta2.
rgds,
Johan
CodeTyphon 3.00 Beta1 in XP 14 years 1 month ago #2704
  • Stefano
  • Stefano's Avatar
sternas wrote: We found the problem Sir
pl_ORCA {$DEFINE DIRECT3D_VERSION_9_VISTA} definition...
I am glad you found the problem and I am waiting for the next beta release.
This does not clear the question however...how did you get CT 2.9 and 3.0 beta 1 to start on a real XP machine when all of us couldn't ?
You must have done or installed something extra in your XP testing machines other than the DirectX End User runtime you told us because CT >= 2.90 apparently doesn't work in none of our true XP machines.
steve
CodeTyphon 3.00 Beta1 in XP 14 years 1 month ago #2707
we have 5 old computers in our lab with WinXP+SP3
I don't know the OS setup history of these systems.
We make all CT tests for XP, on these systems.
Please, don't forget PilotLogic is a "small" software house
with about 23 computers and 15 people (10 crazy programmers) for now...
"Small Budget Schema".
But, I give you my promise for better "Commercial Level" tests and support for WinXP OS
The following user(s) said Thank You: Adriano Soares
CodeTyphon 3.00 Beta1 in XP 14 years 1 month ago #2710
  • 4aiman's Avatar
Thanks you, sternas, for your answers :)
But again, may we ask a list of installed software/updates (if any) on the one of those machines and some other info? You may not know the history but you may obtain current status of the OSes - and that we are asking for ;)
You may have full config info in no time using pc-wizard - it's absolutely free (not an ads).
Part of the message is hidden for the guests. Please log in or register to see it.
Thanks for all that you've done and doing right now! :)
CodeTyphon 3.00 Beta1 in XP 14 years 1 month ago #2718
  • 4aiman's Avatar
Some more of the strange things:
I've installed CT 3.0 under win XP (home, sp2, just installed it + directx june2010) running in the virtual box. Virtual box is installed in win xp sp3 (the very same home edition, cause the guest and the host systems are fom the same disk).
Then I copied compiled CT from guest to host and got the same d3d9.dll error as in the 2.9 version...
For some strange reason I can't compile 3.0 under my host system even after cleaning %PATH% and uninstalling various software (dev-c++, ds gamemaker, cygwin, GNU win package etc.)...
So my point is CT need some other way to check OS's librares and it's capabilities. I mean, some time ago one could successfully compile CT under guest and then copy it to the host. And now one can't.
Oh, this is just my thoughts, if problems with d3d9.dll allready solved, then ignore them ;)
CodeTyphon 3.00 Beta1 in XP 14 years 1 month ago #2719
Yes Sir
WinXP problem with DirectX, solved
The following user(s) said Thank You: Ramon Retamar
CodeTyphon 3.00 Beta1 in XP 14 years 1 month ago #2722
  • Miquel Matas
  • Miquel Matas's Avatar Topic Author
  • Thank you received: 10
It will be Beta 2 or a 3.1?
Cheers,
Miquel.
CodeTyphon 3.00 Beta1 in XP 14 years 1 month ago #2723
Sir,
we prepare CT Ver 3.00 beta2
The following user(s) said Thank You: Miquel Matas, Ramon Retamar
CodeTyphon 3.00 Beta1 in XP 14 years 2 weeks ago #2767
  • Pierre Joubert
  • Pierre Joubert's Avatar
Hi
I am running:
1. A KVM virtual machine under Linux without 3D hardware acceleration (there is no drivers available at this stage).
2. Windows XP installed from a XP CD with service pack 2 and then applied service pack 3.
3. I disabled updates to the operating system.
I have installed CodeTyphonIns.2.90 and it is running without problems.
It seems as if I would not be able to run CodeTyphonInsb3.0.1 because it depends on 3D hardware acceleration?
Would the next release of CodeTyphon be dependent on 3D hardware acceleration or would it only be an option?
Thank's
Pierre
4aiman wrote: Some more of the strange things:
CodeTyphon 3.00 Beta1 in XP 14 years 6 days ago #2786
  • 4aiman's Avatar
It is possible to install CT 3.0 in a virtual machine, although REAL OS on a real HW wouldn't let you to do this ;)
CodeTyphon 3.00 Beta1 in XP 14 years 6 days ago #2787
Guys
we solve REAL XP OS Direct X problems
please test CodeTyphon 3.0 and report here
The following user(s) said Thank You: Johan
CodeTyphon 3.00 Beta1 in XP 14 years 4 days ago #2794
  • Johan
  • Johan's Avatar
All working on my XPSP3 at work, a big thanks you from me.
CodeTyphon 3.00 Beta1 in XP 14 years 3 days ago #2798
  • Miquel Matas
Tested at home XP.
Solved!
Cheers,
Miquel.
CodeTyphon 3.00 Beta1 in XP 14 years 3 days ago #2799
