The procedure entry point not found in d3d9.dll. 14 years 1 month ago #2556
  • wolfram
  • wolfram's Avatar Topic Author
Lazarus in CT2.90 do not run.
I get the error "Procedure entry point "Direct3DCreate9Ex" not found in the DLL d3d9.dll" after start of lazarus.
The procedure entry point not found in d3d9.dll. 14 years 1 month ago #2557
  • Miquel Matas
  • Miquel Matas's Avatar
  • Thank you received: 10
Please, elaborate.
The procedure entry point not found in d3d9.dll. 14 years 1 month ago #2561
  • f00l
  • f00l's Avatar
My poor English~
OK,I get the same issue
It occur on WinXP 32bit at CT2.9 BigIDE
So cannot start Lazarus BigIDE
Seem that Direct3DCreate9Ex only Exists in Vista and Up
So may CT2.9 include New packages(DirectX11?) With Direct3DCreate9Ex Binding
I am not good at Pascal, we may can found where it declared and Set it as Later Binding or Use {$IFDEF}?
I found {$DEFINE DIRECT3D_VERSION_9_VISTA} in Line 53 at C:\codetyphon\lazarus\components\pl_Win_DirectX\source\Direct3D9.pas
So Is it Missing some limit like {$IFDEF WinVersion>5.1}?
The procedure entry point not found in d3d9.dll. 14 years 1 month ago #2562
  • Johan
  • Johan's Avatar
I'am having this error also, it happens when I startup lazarus on winxp SP3, could not test on a win7 machine, no messages found according this in the eventvwr of the system. Can you advice?
The procedure entry point not found in d3d9.dll. 14 years 1 month ago #2563
  • f00l
  • f00l's Avatar
The same in
C:\codetyphon\lazarus\components\pl_ORCA\source\inc3d\orca_scene3d_canvas_directx.inc
C:\codetyphon\lazarus\components\pl_Win_DirectX\source\DirectDraw.pas
and may be more
Last edit: by f00l.
The procedure entry point not found in d3d9.dll. 14 years 1 month ago #2564
  • Miquel Matas
Last edit: by Miquel Matas.
The procedure entry point not found in d3d9.dll. 14 years 1 month ago #2566
  • Johan
  • Johan's Avatar
Hi, I downloaded the latest runtimes from Directx but still nog go concerning lazarus. The previous version still works, version 2.80
Kind Regards.
The procedure entry point not found in d3d9.dll. 14 years 1 month ago #2567
  • wolfram
I have already installd the lates Version of DirectX.
I installed it after the compile of the big IDE!
Do i have to rebuild the big IDE after installaion of DirectX?
Best Regards
The procedure entry point not found in d3d9.dll. 14 years 1 month ago #2569
  • Serge Lebedev
  • Serge Lebedev's Avatar
miquelmatas wrote: Please, see if this could help you:
www.pilotlogic.com/codetyphon/help/index...?directx_samples.htm
this is not could help to me, because my Lazarus IDE (big IDE), was correctly compilied, on Windows XP SP3 can not start, crushes with error message "The procedure entry point not found in d3d9.dll". Problem is with a presence into IDE one of a DirectX packages, why is not compatible with last available DirectX for XP.
Thats, CodeTyphon 2.90 is for Vista or above only?
If no, which way I should fix this problem?
Manually remove problem package from make files?
what package? and how it must be removed?
Guys, not only your monitors is biggest than others users of codetyphoon, but Windows also ))
Thanks.
The procedure entry point not found in d3d9.dll. 14 years 1 month ago #2570
  • Miquel Matas
I'll try to install CT 2.9 in a Virtual XP machine.
Get in touch....
The procedure entry point not found in d3d9.dll. 14 years 1 month ago #2573
  • Miquel Matas
So, please, Sternas:
pl_Win_DirectX11 package produces error on XP systems.
"Direct3DCreate9Ex is supported only in Windows Vista, Windows Server 2008, and Windows 7"
People with Windows XP is unable to run CT 2.9 BIGIDE, could you remove DirectX packages?
Or, how can we desactivate them? and re-build lazarus?
Cheers,
Miquel.
The procedure entry point not found in d3d9.dll. 14 years 1 month ago #2574
  • Aleksandar
  • Aleksandar's Avatar
  • Thank you received: 31
miquelmatas wrote: So, please, Sternas:
Cheers,
Miquel.
I had an idea that I proposed to Avra some time ago (when he proposed the idea about tool for package maintenance), but never had time to test it myself. This response is based on that same idea, so you can try this. :)
Please check this file
c:\codetyphon\bin\settings\win64\slazarus\miscellaneousoptions.xml
I hope that path is correct, since I am on Linux.
For 32bit go to win32 instead of win64.
Find this line, remove it, save file and recompile Big IDE.
<Item24 Value="pl_Win_DirectX11"/>
If that is not enough, you can also try to remove
    <Item63>
      <Name Value="pl_Win_DirectX11"/>
      <Version Major="1"/>
      <Filename Value="components\pl_Win_DirectX11\pl_win_directx11.lpk"/>
      <LastUsed Value="20120829"/>
    </Item63>
from this file
c:\codetyphon\bin\settings\win64\slazarus\packagefiles.xml
I hope it will work.
Please let me know about the results.
Last edit: by Aleksandar. Reason: fixed mess that i made in this post
The procedure entry point not found in d3d9.dll. 14 years 1 month ago #2576
  • Ramon Retamar
  • Ramon Retamar's Avatar
wosc wrote: Lazarus in CT2.90 do not run.
I get the same error in Windows XP 32 SP3.
The "Direct3DCreate9Ex" function is only for Windows Vista and Windows 7.
The old version 2.80 works fine. :( ¿ The new version 2.90 is only for Windows Vista or Windows 7 ?
Last edit: by Ramon Retamar.
The procedure entry point not found in d3d9.dll. 14 years 1 month ago #2579
Did you install
MS DirectX End-User Runtimes Sir?
more info and links here
The procedure entry point not found in d3d9.dll. 14 years 1 month ago #2580
  • Ramon Retamar
sternas wrote: Did you install
Windows XP SP3 support DirectX version 9 or lower. My Windows XP SP3 has installed this version.
The version 10 of DirectX only works into Windows Vista or Windows Seven.
The Codetyphon BigIDE 2.90 is searching for DirectX version 10, and don't start on Windows XP SP3.
The procedure entry point not found in d3d9.dll. 14 years 1 month ago #2581
Yes Sir
but did you install MS DirectX End-User Runtimes ?
In our LAB we have 5 PC with WinXP and with CodeTyphon 2.90
The procedure entry point not found in d3d9.dll. 14 years 1 month ago #2582
  • tt
  • tt's Avatar
Просто закомментируйте в
C:\codetyphon\ScriptsWin\x_Lazarus_Win32_Build.bat
строчку
START /B /WAIT ..\lazarus\bin32\lazbuild.exe --create-makefile ..\lazarus\components\pl_Win_DirectX11\pl_win_directx11.lpk
получится что то типа
START /B /WAIT ..\lazarus\bin32\lazbuild.exe --create-makefile ..\lazarus\components\pl_Win_DirectX\pl_win_directx.lpk
rem START /B /WAIT ..\lazarus\bin32\lazbuild.exe --create-makefile ..\lazarus\components\pl_Win_DirectX11\pl_win_directx11.lpk
START /B /WAIT ..\lazarus\bin32\lazbuild.exe --create-makefile ..\lazarus\components\pl_Win_DirectXUT\pl_win_directxut.lpk
и дальше в файле setup.bat выбираете опцию
6) Remove and Build Lazarus
или
8) Remove and Build ALL
The procedure entry point not found in d3d9.dll. 14 years 1 month ago #2583
  • Adriano Soares
  • Adriano Soares's Avatar
English version:
Simply comment out
C: \ codetyphon \ ScriptsWin \ x_Lazarus_Win32_Build.bat
line
START / B / WAIT .. \ lazarus \ bin32 \ lazbuild.exe - create-makefile .. \ lazarus \ components \ pl_Win_DirectX11 \ pl_win_directx11.lpk
get something like
START / B / WAIT .. \ lazarus \ bin32 \ lazbuild.exe - create-makefile .. \ lazarus \ components \ pl_Win_DirectX \ pl_win_directx.lpk
rem START / B / WAIT .. \ lazarus \ bin32 \ lazbuild.exe - create-makefile .. \ lazarus \ components \ pl_Win_DirectX11 \ pl_win_directx11.lpk
START / B / WAIT .. \ lazarus \ bin32 \ lazbuild.exe - create-makefile .. \ lazarus \ components \ pl_Win_DirectXUT \ pl_win_directxut.lpk
and further into the file setup.bat choose an option
or
The following user(s) said Thank You: Stefano, Ramon Retamar, Alfons Kemming
The procedure entry point not found in d3d9.dll. 14 years 1 month ago #2589
  • Ramon Retamar
I try to install from this link: www.microsoft.com/download/en/details.aspx?id=35
And obtain the message "The installed version is more recent" in WinXP SP3. And Codetyphon don't work.
The procedure entry point not found in d3d9.dll. 14 years 1 month ago #2593
  • Johan
  • Johan's Avatar
Performed as requested but lazarus still doesn't start, will try the other method that comments out the dx version.
When I comment out the entries I can open Lazarus, no problems anymore.
The following user(s) said Thank You: Ramon Retamar
Last edit: by Johan.
