CT2.80, failed to build BIGIDE 14 years 3 months ago #2415
  • frtrnr
  • frtrnr's Avatar Topic Author
the log shows the errors hapened to virtualtree, as indicated in the last few sentences:
VTGraphics.pas(8,15) Hint: Unit "DelphiCompat" not used in VTGraphics
VirtualTrees.pas(1027,20) Error: No matching implementation for interface method "IDropSource.QueryContinueDrag(LongBool,LongInt):LongInt; StdCall;" found
VirtualTrees.pas(1027,20) Error: No matching implementation for interface method "IDropSource.GiveFeedback(LongInt):LongInt; StdCall;" found
VirtualTrees.pas(1223,15) Warning: An inherited method is hidden by "TVirtualTreeColumn.Equals(TObject):Boolean;"
VirtualTrees.pas(1319,14) Warning: An inherited method is hidden by "TVirtualTreeColumns.Equals(TObject):Boolean;"
VirtualTrees.pas(2465,15) Warning: An inherited method is hidden by "TBaseVirtualTree.SetVisible(PVirtualNode,Boolean);"
VirtualTrees.pas(2677,15) Warning: An inherited method is hidden by "TBaseVirtualTree.FontChanged(TObject);"
VirtualTrees.pas(3855,1) Fatal: There were 2 errors compiling module, stopping
Fatal: Compilation aborted
make.exe[2]: *** [pl_virtualtrees.ppu] Error 1
make.exe[2]: Leaving directory `C:/codetyphon/lazarus/components/pl_VirtualTrees'
make.exe[1]: *** [bigide] Error 2
make.exe[1]: Leaving directory `C:/codetyphon/lazarus/components'
..\fpc\bin\i386-win32\make.exe: *** [bigidecomponents] Error 2
[ERROR]: Lazarus32 BIG-IDE NOT Build
I am new to lazarus, I 'm wondering how long it is towards the success of building the bigIDE. (building win32 on 64bit win7 OS)
Can anyone help me out? thank you very much!
CT2.80, failed to build BIGIDE 14 years 3 months ago #2417
  • frtrnr
The problem is solved.
the cause of the problem is due to FPC2.60 I had installed before, So I removed it before compiling the big IDE.
I found it on the Lazarus forum, that a patch is done to the virtualtree package in order to build with FPC 2.70, which had been applied to CT 2.8 already (what a quick action! great CT developers.).
so please remove this thread!
CT2.80, failed to build BIGIDE 14 years 3 months ago #2418
CT use always the latest working SVN revisions
have fun
