Alternative compression method for setup package 14 years 3 months ago #2338
  • Aleksandar
  • Thank you received: 31
I noticed that you use very high compression level when pack CodeTyphon release. I guess that you need to make as small package as possible in order to reduce bandwidth, but sometimes it takes ages to uncompress it (especial in virtual machines).
Some of us have very fast internet connections, so bigger download package with lesser compression would be much convenient method of delivery for us. I would be happiest if I could get tar archive without any compression, but I know that this is not possible.
Would you please at least think about some alternative compression method? For example 7zip makes smaller archive then zip with less compression.
You could also make "advanced" download package that would not have Lazarus and FPC sources included. The one who want to download that package would be responsible to download appropriate sources from svn himself. So for example I would need Lazarus Rev 37429 and FreePascal Rev 21396 for CT 2.70.
This is not exactly same idea as already proposed idea about modifications as patches (which I think is very good one).
Alternative compression method for setup package 14 years 3 months ago #2339
1) for completion we can upload and one file with 7zip completion
2) Lazarus and Freepascal source are Tested/Fix before every release
a)for sample current FPC SVN 21977 (with out our modifications)
-don't build on win32/win64/Win8
-don't build 80% of crossbuild targets
-don't build on Solaris
-don't build on FreeBSD
b)current Lazarus svn 21977 (with out our modifications)
-has problem to lazbuild at all unix OSes (svn 37960 IDE: using UTF8CompareText)
So, we don't want to separate CodeTyphon, from our tested Lazarus and Freepascal source.
We must deliver a Programming Studio capable of making applications...
The following user(s) said Thank You: Konstantinos Papadoulas, FredyCC
