Problem at install RichMemo and LzRichEdit 14 years 6 months ago #1893
  • mtbf40
  • mtbf40's Avatar Topic Author
Problem with the new Version CT 2.60:
you can't install the Components RichMemo and LzRichEdit with the new Version from CT - but you can! install both Components with Version CT 2.50
Can you check what is the difference between the Versions? thx
System: Win7 64bit/32bit - Lazarus 32bit
mtbf40
