CodeTyphon Center 2.60: missing menu options Cross 14 years 7 months ago #1854
  • Rain
  • Rain's Avatar Topic Author
CodeTyphon Center 2.60: missing menu options in
Menu: Cross-Build:
Lazarus 32bits ->
Lazarus 64bits ->
Only
FreePascal 32bits ->
FreePascal 64bits ->
are available. (talking about Win32 and Win64 CT-Center versions)
In previous CodeTyphon Center 2.50 all 4 menu options were available.
Is this change made by design or by something else ?
Last but not least: A big Thank You for all the sustained effort spent in this project and for the new version.
Re: CodeTyphon Center 2.60: missing menu options Cross 14 years 7 months ago #1855
Lazarus 1.1 has the ability
to build "on the fly" or "when need" the RTL-LCL platform units (CT 2.50 Lazarus Cross-Element)
For sample:
If you build freepascal Cross-Element for arm-wince (CT Freepascal Cross-Element)
and try to build a lazarus project for arm-wince
Lazarus first, build Cross-Build RTL-LCL units
So not need Lazarus Cross-Build CodeTyphon procedure anymore...
Simplicity
The following user(s) said Thank You: Konstantinos Papadoulas, Rain
