Trying to Move CodeTyphon To USB Drive 16 years 7 months ago #168
  • saturn
  • saturn's Avatar Topic Author
Installed CodeTyphon (WinXP SP3 / on c drive). Started up and run properly.
I copied the "lazarus", "pp" directory to a USB drive. I changed all reference of c:\ in all xml files under folder "lazarus\bin32\settings" to the drive letter of the USB drive. I also changed all references of c:\ in the fpc.cfg under folder "pp\bin\i386-win32" to the drive letter of the USB drive.
When I run lazarus.exe from the USB drive, it still said "The free pascal compiler (filename: fpc.exe) was not found".
Any one has any idea what else I need to change?
