IDE problem with the message window 14 years 9 months ago #1658
  • Nicola
  • Nicola's Avatar Topic Author
I installed the version 2.50 of Code Typhon but, in the IDE, I can not see the message window. Use windows 7 64 bit. Is there a solution? Thanks
Re: IDE problem with the message window 14 years 8 months ago #1659
Try IDE View->Messages
or post a screen with the problem
Re: IDE problem with the message window 14 years 8 months ago #1661
  • Miquel Matas
  • Miquel Matas's Avatar
  • Thank you received: 10
Please, also check if screen resolution is big enough.
I use 1280x1024.
Re: IDE problem with the message window 14 years 8 months ago #1669
  • Nicola
I solved by changing the coordinates of the window WindowMessage in the file
C:\codetyphon\bin\settings\win32\slazarus\environmentoptions.xml. Thank you
Re: IDE problem with the message window 14 years 8 months ago #1676
  • Konstantinos Papadoulas
  • Thank you received: 19
Changing coordinates of a window can also be done within the Lazarus IDE :)
Re: IDE problem with the message window 14 years 8 months ago #1687
  • Serge Lebedev
  • Serge Lebedev's Avatar
papadouk wrote: Changing coordinates of a window can also be done within the Lazarus IDE :)
No. In IDE of Lazarus, packaged by CodeTyphon 2.50, this settings are removed from IDE parameters dialog.
please, make a default values for windows positions and its sizes into file /codetyphon/bin/settings/{OS}/slazarus/environmentoptions.xml with correspondency to screens 1024x600 or 1024x768; Currently default huge values is real problem for novice!
And more correctly maybe make adaptation for current screen resolution within installation process.
The following user(s) said Thank You: Curt
Re: IDE problem with the message window 14 years 8 months ago #1690
We will add your suggestion to
CT To-Do list for next version
Re: IDE problem with the message window 14 years 8 months ago #1691
  • Gintas
  • Gintas's Avatar
  • Graphics Designer/Developer
You actually need to edit the "GlassDocking.xml"
and link source view with messages window:
<Item1 Name="AnchorDockSite2" Type="Layout" ChildCount="3">
          <Bounds Top="92" Width="1145" Height="511" SplitterPos="87"/>
          <Anchors Align="Bottom"/>
          <Item1 Name="SourceNotebook" Type="Control">
            <Bounds Left="226" Width="919" Height="511"/>
            <Anchors Left="AnchorDockSplitter2"/>
    <Item2 Name="MessagesView" Type="Control">
        <Bounds Left="270" Top="796" Width="927" Height="90">
          <WorkArea>
            <Rect Right="1366" Bottom="734"/>
          </WorkArea>
        </Bounds>
      </Item2>
          </Item1>
