BigIde not compile on CT 2.40 over WinXp 32bit 14 years 10 months ago #1503
  • Maximiliano
  • Maximiliano's Avatar Topic Author
:angry:
I try to install on winxp 32 bit,on a virtual machine Virtualbox with 512mb ram, but do not install the bigide gives an error that can not linking libimpdaemonapp.ay below says Fatal: No memory left. I do not understand if it is lack of memory or file missing
Intento instalar sobre winxp 32 bits, pero no instala el bigide da un error que no puede linkear libimpdaemonapp.a y mas abajo dice Fatal: No memory left. No entiendo si es falta de memoria o que falta un archivo
-Fu../components/pl_Imaging/lib/i386-win32 -Fu../components/pl_GeoGIS/lib/i386-win32 -Fu../components/pl_OpenGL/lib/i386-win32 -Fu../components/pl_Cindy/lib/i386-win32 -Fu../components/pl_Box2D/lib/i386-win32 -Fu../components/pl_PascalScript/lib/i386-win32 -Fu../components/pl_KControls/lib/i386-win32 -Fu../components/pl_LazBarcodes/lib/i386-win32 -Fu../components/pl_Orpheus/lib/i386-win32 -Fu../components/pl_JVCL/lib/i386-win32 -Fu../components/pl_RX/lib/i386-win32 -Fu../components/pl_WST/lib/i386-win32 -Fu../components/pl_CHelper/lib/i386-win32 -Fu../components/pl_ZMSQL/lib/i386-win32 -Fu../components/pl_JujiboUtils/lib/i386-win32 -Fu../components/pl_RichView/lib/i386-win32 -Fu../components/pl_ACS/lib/i386-win32 -Fu../components/pl_ASIOVST/lib/i386-win32 -Fu../components/pl_LAVA/lib/i386-win32 -Fu../components/pl_ExtentIDE/lib/i386-win32 -WG -di386 lazarus.pp
lazarus.pp(205,1) Warning: Library libimpdaemonapp.a not found, Linking may fail !
make.exe[2]: *** [lazarus.exe] Error 1
make.exe[2]: Leaving directory `C:/codetyphon/lazarus/ide'
make.exe[1]: *** [bigide] Error 2
make.exe[1]: Leaving directory `C:/codetyphon/lazarus/ide'
..\fpc\bin\i386-win32\make.exe: *** [idebig] Error 2
[ERROR]: Lazarus32 BIG-IDE NOT Build
[INFO]: Skip 64bit actions, this is 32 bits system...
Terminate Action at 10/01/2012 05:52:33
ExitCode : 0
Re: BigIde not compile on CT 2.40 over WinXp 32bit 14 years 10 months ago #1504
Sir simple,
give more memory to VirtualBox, for sample 2048mb or 1024mb
The following user(s) said Thank You: Maximiliano
Re: BigIde not compile on CT 2.40 over WinXp 32bit 14 years 10 months ago #1505
  • Maximiliano
this is a problem more memory finish ok. Thank Sir
Re: BigIde not compile on CT 2.40 over WinXp 32bit 14 years 10 months ago #1506
Thanks Sir, have fun...
