Unable to build 64 bit Lazarus IDE 15 years 1 month ago #1314
  • Dann Corbit
  • Dann Corbit's Avatar Topic Author
CodeTyphoon Center version 2.1.0
Here is the tail end of the command output window that shows the error:
C:/pp/bin/x86_64-win64/make.exe -C packager/registration all
make.exe[1]: Entering directory `c:/lazarus/packager/registration'
C:/pp/bin/x86_64-win64/rm.exe -f ../units/x86_64-win64/fcllaz.ppu
C:/pp/bin/x86_64-win64/ppcx64.exe -MObjFPC -Scghi -O1 -gl -vewnhi -l -Fu. -Fuc:/pp/rtl -FE. -FU../units/x86_64-win64 -dx86_64 fcllaz.pas
Hint: Start of reading config file C:\pp\bin\x86_64-win64\fpc.cfg
Hint: End of reading config file C:\pp\bin\x86_64-win64\fpc.cfg
Free Pascal Compiler version 2.7.1 [2011/08/25] for x86_64
Copyright (c) 1993-2011 by Florian Klaempfl and others
Target OS: Win64 for x64
Compiling fcllaz.pas
Fatal: Can't find unit system used by fcllaz
Fatal: Compilation aborted
make.exe[1]: *** [fcllaz.ppu] Error 1
make.exe[1]: Leaving directory `c:/lazarus/packager/registration'
C:\pp\bin\x86_64-win64\make.exe: *** [packager/registration] Error 2
ERROR: Lazarus64 BigIDE IDE NOT Build
Terminate Action at 9/29/2011 16:14:25
ExitCode : 2
Re: Unable to build 64 bit Lazarus IDE 15 years 1 month ago #1315
Please Sir,
remove all freepascal and lazarus previous installations and
try again
Re: Unable to build 64 bit Lazarus IDE 15 years 1 month ago #1316
  • Dann Corbit
I removed my freepascal folder tree and my lazarus folder tree (leaving only the original CodeTyphoon folders). Then I did a source extract, then I did a build of the compiler.
It had more failures :
C:/pp/bin/x86_64-win64/ppcx64.exe -Ur -Xs -O2 -n -Fux86_64 -Fusystems -Fuc:/pp/rtl/units/x86_64-win64 -Fix86_64 -FE. -FUx86_64/units/x86_64-win64 -dRELEASE -dx86_64 -dGDB -dBROWSERLOG -Fux86 pp.pas
aasmtai.pas(398,11) Warning: Constructor should be public
t_win.pas(1760,81) Error: Wrong number of parameters specified for call to "AddExternalImport"
t_win.pas(1831) Fatal: There were 1 errors compiling module, stopping
make.exe[5]: *** [ppcx64.exe] Error 1
make.exe[5]: Leaving directory `c:/pp/compiler'
make.exe[4]: *** [next] Error 2
make.exe[4]: Leaving directory `c:/pp/compiler'
make.exe[3]: *** [ppc1.exe] Error 2
make.exe[3]: Leaving directory `c:/pp/compiler'
make.exe[2]: *** [cycle] Error 2
make.exe[2]: Leaving directory `c:/pp/compiler'
make.exe[1]: *** [compiler_cycle] Error 2
make.exe[1]: Leaving directory `c:/pp'
C:\pp\bin\x86_64-win64\make.exe: *** [build-stamp.x86_64-win64] Error 2
Install FreePascal 64bit
make.exe[1]: Leaving directory `c:/pp/installer'
C:/pp/bin/x86_64-win64/rm.exe -f build-stamp.*
C:/pp/bin/x86_64-win64/rm.exe -f base.build-stamp.*
File not found - bin
0 File(s) copied
The system cannot find the file specified.
Terminate Action at 9/30/2011 12:58:45
ExitCode : 4
I conclude that the CodeTyphoon download is broken.
Re: Unable to build 64 bit Lazarus IDE 15 years 1 month ago #1317
Please Sir, try and new CodeTyphon ver 2.20
Re: Unable to build 64 bit Lazarus IDE 15 years 1 month ago #1332
  • Dann Corbit
I will give it a try.
Re: Unable to build 64 bit Lazarus IDE 15 years 2 weeks ago #1375
  • Dann Corbit
I was able to build the compiler with version 2.20
