GDB problem in CT 2.00 15 years 2 months ago #1189
  • avra
  • avra's Avatar Topic Author
Applications compile well, but do not start in IDE since GDB gives this message:
gdb.exe has encountered a problem and needs to close.
We are sorry for the inconvenience.
I have found a workaround to copy c:\pp\binGDB\win32 from the previous version I had (CT 1.60). Debugging now seams to work well so far (watches, steps, local variables...)
WinXP SP3, Lazarus CT 2.00
Last edit: by avra.
Re: GDB problem in CT 2.00 15 years 2 months ago #1191
I will put this to next ver only for WinXP
Re: GDB problem in CT 2.00 15 years 2 months ago #1192
  • Rain
  • Rain's Avatar
avra wrote: Applications compile well, but do not start in IDE since GDB gives this message:
Can confirm the Problem and the solution too here in WinXP.
Copied from previous CodeTyphon_180.zip (1.80, not from 1.60):
CodeTyphon_180\binGDB\win32\gdb.exe
to:
c:\pp\binGDB\win32\gdb.exe
and it works now, as it did previously, very well.
Thanx for CT v2.00 by the way!
Re: GDB problem in CT 2.00 15 years 2 months ago #1193
GDB 7.3.50 Working OK with Win7 32/64
I am thinking to upload CT 2.10 with GDB Rollback...
today, but we will see...
Re: GDB problem in CT 2.00 15 years 2 months ago #1194
  • 4aiman's Avatar
That problem people speak about, has nothing to do with XP itself, but the way gdb deal with paths.
I don't have installed XP, but maybe someone try to move his/her project folder nearer to the drive root or check if there are national characters/spaces in the path. In CT v 1.60 this measures did the trick and gdb began to work properly.
Sometimes change codepage nls1252 to nls1251 in the regedit did the trick too, but that's seem to be dependent from weather on Mars or some abnormal magnet fields...
So try the first one solution, maybe the thing is in paths.
Re: GDB problem in CT 2.00 15 years 2 months ago #1195
GDB 7.0.50 working OK with all Windows (XP, vista, Win7)
GDB 7.3.50 has problem with winXP
after my tests
So, I will put new GDB 7.3.50 in binGDB folder for test (xnewGDB)
GDB 7.0.50 will be the default for installation
I must rebuild (again) GDB from SVN source...like 7.3.50
