IDE Base and IDE Extensions Components and Libraries, discussions, problems and suggestions
Docked form/window doesn't show again 4 years 3 months ago #17147
  • Andrew John Richter Cass
Hi
I'm trying to use Glassdock but i'm having the fallowing issue:
  If i close a docked window/form (using the close icon[X] on dock header) the command "Form1.Show" doesn't show the form anymore!
Thanks for any help
Docked form/window doesn't show again 4 years 3 months ago #17148
  • Thank you received: 231
Your OS and CT version ?
Docked form/window doesn't show again 4 years 3 months ago #17149
Windows 10
CT version 7.9
On glassdock examples this problem can be easily viewed...
Last edit: by Andrew John Richter Cass.
Docked form/window doesn't show again 4 years 3 months ago #17150
New pl_GlassDocking pkg
with some new functions and ShowHeaderCloseButton option
look at new pl_GlassDocking_CodeOcean
now we use
procedure TForm1.Button2Click(Sender: TObject);
 if Form2=Nil then
  Application.CreateForm(TForm2, Form2);
 GlassDockEngine1.ShowForm(Form2,False);
