Problem with ORCA2D on linux 8 years 7 months ago #11524
  • Jean-Philippe FABRE
  • Jean-Philippe FABRE's Avatar Topic Author
I'm trying Orca2D demos projects on linux and i found this problem:
When the main window is resized at runtime all the orca controls
inside the window are blocked, nothing happens when I click, but the program does not crash.
The same demos projects on windows 10 run well.
Best regards
Problem with ORCA2D on linux 8 years 7 months ago #11525
  • Thank you received: 236
any sample app
for our tests?
Please, give us more info
-Your CT version ?
-Your Linux Distribution?
-32bits or 64bit?
Problem with ORCA2D on linux 8 years 7 months ago #11526
The application is ctrlscontrol demo in coptetyphon demos folder: codeocean->pl_orcad2d->samples->ctrlsdemo->ctrlsdemos.ctpr.
I've tried this code on both 32 bits and 64 bits linux:
Ubuntu 17.10, 17.4, 16.4
PCLinuxOS last version
Code typhon version : 6.0 to 6.4
I've tried on 2 laptop ( dell and asus), and I 've tried also using linux into virtualbox on windows10 and macos,
in all the case the problem is the same on linux.
Thank for you reply.
Problem with ORCA2D on linux 8 years 7 months ago #11527
we conform this problem.
Please, give time to fix it
