Graphics32 problem on UBUNTU 12.04 LTS 12 years 7 months ago #5244
  • jfmadre60
  • jfmadre60's Avatar Topic Author
I am completely novice on Linux. I try to compile under Linux a soft writed under Lazarus windows.
CodeTyphon installation seems to work properly (Thanks :) ), But Graphics32 of CodeTyphon under Linux Ubuntu do not works properly :
trying to write something in a TImage32 (either using Image32.Bitmap.Textout or RenderText function causes an error in the unit unit GR32_Backends_LCL_Gtk.
it seems that the FCanvas used in TLCLBackend remains always = nil, and then all the function using the Canvas property of the Bitmap32 causes an error.
Draw function also does'nt work.
I have found no solution except create in my soft a TBitmap , writing the text in it, and copy the result pixel by pixel using Pixels functions.
Is there a better solution ?
Graphics32 problem on UBUNTU 12.04 LTS 12 years 7 months ago #5245
Thanks Sir,
can you give us more source info and your CT ver ?
Graphics32 problem on UBUNTU 12.04 LTS 12 years 7 months ago #5246
  • jfmadre60
CT 4.70
Minimum Source to detect the problem :
1 MainForm with just 1 component TImage32, 1 TEdit to enter text and a button to write the text of the edit on the Timage32
Image32 : TImage32;
Edit1 : TEdit;
Button1 : TButton;
procedure TMainForm.FormCreate(Sender: TObject);
Image32.Bitmap.Width:=Image32.Width;
Image32.Bitmap.Height:=Image32.Height;
Image32.Bitmap.Clear($FFFFFFFF);
procedure Button1Click(Sender: TObject);
Image32.Bitmap.TextOut(5,5,Edit1.Text);
There is an error when I click on the Button (that calls Button1Click). Any other TBitmap32 procedure that uses at any moment the Canvas property (RenderText, Draw, TextWidth...) causes also an error.
Thanks for your help.
