OnGuard license code validation and activation 1 year 8 months ago #18826
  • tatamata
  • tatamata's Avatar Topic Author
File Name: ulicensema...23-2.txt
File Size:24 KB
Attached is my ULicenseManager unit for validation and activation of license codes generated by demo OnGUard code generation program in the CodeOcean.
You will see some terrible hacks inside, for example for proper interpretation of encoded dates. It should be probably much better to debug the OnGuard itself. But, hey, it works! :-)
You can use it something like this:
procedure TAboutForm.CheckLicense;
  LM: TLicenseManager;
  Details: string;
  NewCode: string;
  LM := TLicenseManager.Create(Self);
  try
    if LM.ActivateLicense(EditLicenseCode.Text, EditMachineCode.Text, Details) then
      LabelLicenseStatus.Caption := 'License: VALID';
      MemoLicenseStatusDetails.Lines.Text := Details;
      MainForm.IsLicenseActive := True;
      // Critical update: Refresh license code from storage
      NewCode := ReadLicenseCode;  // Or use LM's method if available
      EditLicenseCode.Text := NewCode;  // Update UI with new license code
      {$IFDEF DebuggingMode}
      DebugLog('? UI License Code Updated: ' + NewCode);
      {$ENDIF}
    end
    else
      LabelLicenseStatus.Caption := 'License: INVALID';
        'Activation Failed' + sLineBreak + Details;
      MainForm.IsLicenseActive := False;
  finally
    LM.Free;
Last edit: by tatamata.
OnGuard license code validation and activation 1 year 8 months ago #18827
  • Thank you received: 234
We will test and report
