Virtualstringtree, problem with scrollbars 6 years 11 months ago #14083
  • Stefan
  • Stefan's Avatar Topic Author
i have a Problem with Virtualstringtree and Scrollbars. I dont now how long this Problem exists, i make some tests with Codetyphon 6.8, 6.9 and 7.0 and on this Version i can reproduce it .
If i start my litte Testprogramm i can click the Fill-Button two times to add 30 items and the vertical scrollbar is shown. If i save the tree to a file and load it again, the vertical scrollbar is not shown anymore. I must click the Fill-Buttton two times again to bring it back but then i cant see all the 60 items.
If i compile any of my old project which is using the Virtualstringtree, i have this problem. Is this my mistake or is this a bug ?
Best Regards
Stefan
Virtualstringtree, problem with scrollbars 6 years 11 months ago #14085
Your CPU-OS-Platform ?
Virtualstringtree, problem with scrollbars 6 years 11 months ago #14087
  • Stefan
I am using Windows 10 x64 with Intel CPU on my Notebook and Desktop PC.
Virtualstringtree, problem with scrollbars 6 years 11 months ago #14089
  • Stefan
i have done some more tests.
On my Laptop i have installed Codetyphon 6.7. If i compile here with Typhon32 all is working fine, if i do the same with Typhon64 i get the Problems.
I want to test this on my Desktop-PC with Codetyphon 7 again, but here i have another Problem. I have compiled Typhon64 and 32 as BigIDE but in Typhon32 i am missing many Components. Virtualstringtree is not present on Typhon32 so i can´t compile my Projects here.
Best Regards
Stefan
Virtualstringtree, problem with scrollbars 6 years 11 months ago #14090
  • Stefan
Now i had adding some Components manually to Typhon32 version 7 and here it´s the same. 32 Bit is working, 64 bit not.
Virtualstringtree, problem with scrollbars 6 years 11 months ago #14092
Please
give us time to test your project
Virtualstringtree, problem with scrollbars 6 years 11 months ago #14093
  • Stefan
Of course, I just wanted to share what I've found out so far.
Virtualstringtree, problem with scrollbars 6 years 11 months ago #14094
Tomorrow, I will add a task to our LAB programmers
Virtualstringtree, problem with scrollbars 6 years 11 months ago #14113
  • Stefan
Do you have news, could you reproduce the problem ?
Virtualstringtree, problem with scrollbars 6 years 11 months ago #14114
No yet Sir
Virtualstringtree, problem with scrollbars 6 years 9 months ago #14261
  • Stefan
How is it going, did you find out anything ?
Is this fixed in version 7.0 ?
Virtualstringtree, problem with scrollbars 6 years 9 months ago #14262
I think we fix the problem
just replace old pl_VirtualTrees with new ver 7.1.1
The following user(s) said Thank You: Stefan
Virtualstringtree, problem with scrollbars 6 years 9 months ago #14263
  • Daniel Jaeger
  • Daniel Jaeger's Avatar
Hello Sternas,
confirmed, problem is fixed. Tested with Win 8.1 Pro.
Thank you.
Typhon 7.0 r62514 FPC 3.3.1 r43891 Platform : x86_64-win64-win32/win64
Virtualstringtree, problem with scrollbars 6 years 9 months ago #14275
  • Stefan
yes i can confirm this too. It is working with Windows 10-x64, Typhon 64 & 32 Bit, Version 7, Rev. 62514.
Thank you very much.
Best Regards
Stefan
