Duplicate unit UniqueInstanceRaw 10 years 1 month ago #9697
  • Avra
  • Avra's Avatar Topic Author
If I add pl_luicontrols to Project Inspector and put UniqueInstance component on my form, if I want raw check for another application instance at the very beginning of LPR file by testing for InstanceRunning like this:
if InstanceRunning then      // described at http://wiki.freepascal.org/UniqueInstance#How_To_Use_.28Raw.29
    Exit;
then I am forced to use unit uniqueinstanceraw like this (adding pl_luicontrols package was not enough to recognize InstanceRunning):
uses
  uniqueinstanceraw in 'c:\codetyphon\typhon\components\pl_LuiControls\source\uniqueinstance\uniqueinstanceraw.pas';
After that IDE gives me these hints:
Messages, Hints: 2
Note: Duplicate unit "uniqueinstanceraw" in "pl_luicontrols 5.5.2", source="C:\codetyphon\typhon\components\pl_LuiControls\source\uniqueinstance\uniqueinstanceraw.pas"
Note: Duplicate unit "uniqueinstanceraw" in "L1toOracle", orphaned ppu "M:\Lazarus Projects\L1toOracle\lib\i386-win32\uniqueinstanceraw.ppu"
What needs to be done to solve this duplicate unit problem?
Last edit: by Avra.
Duplicate unit UniqueInstanceRaw 10 years 1 month ago #9698
  • Thank you received: 1141
Did you have in your project options the path of pl_LuiControls ?
1) You can declare in your project, pl_LuiControls as need package,
In this case the CT-FPC use “ppu” from pl_LuiControls/lib/ directory.
2) You can add in your “project options” the path for pl_LuiControls
in this case the CT-FPC will build pl_LuiControls ppu in your project “ppu” out path.
You can’t use both methods at the same time,
because the CT-FPC compiler found in project paths the same ppu 2 times...
it's logical :)
My suggestion is to use the first one.
and delete or clear old “ppu” files from your project out directory
PS: Please always use the latest CT version Stable 5.70 or LAB 5.80
Duplicate unit UniqueInstanceRaw 10 years 1 month ago #9709
  • Avra
Sternas Stefanos wrote: Sir
No (see Lui1 screenshot). I have added pl_LuiControls to ProjectInspector (Lui2 screenshot).
I did as you can see in Lui3 screenshot, but then InstanceRunning from "uniquesinstanceraw.pas" is not found and compiler errors.
This shouldn't be needed if I have added a package, right?
I think I didn't. Look at Lui3 and Lui4 screnshots.
That was what I originally did, but I get error in Lui3 screenshot.
Everything mentioned is running on latest CT LAB 5.80 on WinXP SP3.
Last edit: by Avra.
