WizzardManager WizzardButtonsPanel 11 years 2 months ago #7516
  • Alexandr
  • Alexandr's Avatar Topic Author
Greetings!
A very good controls to realize cool pagination like in setup, but I found two bugs:
1. Help button declared in designer properties but dont't exists visually.
2. Previous and Next buttons don't have their glyphs.
Can you fix that in next dev build?
WizzardManager WizzardButtonsPanel 11 years 2 months ago #7517
  • Alexandr
I've fixed that as I can.
See attachment, used source code from latest dev build.
But two moments:
1.
procedure TWizardButtonPanel.DoOnResize;
  inherited DoOnResize;
  FHelpButton.Left := 10;  //Some resizing staff what need do with it?
  FFinishButton.Left := FCancelButton.Left - FFinishButton.Width - 8;
  FNextButton.Left := FFinishButton.Left - FNextButton.Width - 8;
  FPreviousButton.Left := FNextButton.Left - FPreviousButton.Width - 2;
I think there need do some resize actions.
I never make controls for lazarus. Can you tell me how I can debug controls in run-time without rebuilding the IDE with mod. package?
Second:
Still donk know from where glypths are taken and why Previus, Help and next butons don't have them. In LUIPackage I didn't found resources for buttons.
Last edit: by Alexandr.
WizzardManager WizzardButtonsPanel 11 years 2 months ago #7519
we add your mod to Lab CT
1) you must Rebuild IDE from IDE->Tools->Build Typhon With Profile :
the first time get some time, but after that the rebuild take some seconds
Try to remove some pks from IDE, to minimize the rebuild time
2) For glyths :
TWizardPanelBitBtn is class(TCustomBitBtn)
TCustomBitBtn has default property Kind: TBitBtnKind
This property if is NOT bkCustom gives to button and a glyth from LCL res file
in wizardcontrols.pas Line 604
constructor TWizardButtonPanel.Create(TheOwner: TComponent);
gives to TWizardPanelBitBtn the TCustomBitBtn.Kind property value
The following user(s) said Thank You: Alexandr
WizzardManager WizzardButtonsPanel 11 years 2 months ago #7521
  • Alexandr
Thanks!
I change code according with your comments.
glypths now correctly sets.
For next, prev buttons kind set to bkCustom by default, also glypth must be set by programmer.
WizzardManager WizzardButtonsPanel 11 years 2 months ago #7524
We put your mods to Lab CT, Sir
