Codetyphon - pl_onguard runtime error 11 years 3 months ago #7015
  • Hector S Ponce
  • Hector S Ponce's Avatar Topic Author
Trying to run my program in diferent operative systems: win8, win7, XP, win7 (vmware)
I have a runtime error in line 119 of ogwmi.pas of package pl_onguard.
win8: no errors found
win7: with error
xp: with error
win7 under vmware: with error
the code:
while oEnum.Next(1, FWbemObject, iValue) = 0 do
for a:=0 to fields.Count-1 do
Begin
this line ---> OutBuf:= OutBuf + Trim(string(FWbemObject.Properties_.Item(OLEVariant(fields[a])).Value));
result := OutBuf <>'';
FWbemObject:=Unassigned;
finally .....
changing the line for:
OutBuf:= OutBuf + Trim(VarToStr(FWbemObject.Properties_.Item(OLEVariant(fields[a])).Value));
the problem seems to be solved but the package is still unstable.
did someone know something about these issue?
Codetyphon - pl_onguard runtime error 11 years 3 months ago #7017
  • universe
  • universe's Avatar
Hello, have you tried the same code on the same machine with different OS? Because some hardware codes won't be available
Codetyphon - pl_onguard runtime error 11 years 3 months ago #7023
  • Hector S Ponce
No, I haven't tried it.
I have compared last version of the package (5.21) with the one I have used before and they have many differencies. The old version works fine to me, then I will continue using it.
The version I have is attached.
Last edit: by Hector S Ponce.
Codetyphon - pl_onguard runtime error 11 years 3 months ago #7024
  • Thank you received: 1141
please look at pl_OnGuard pkg unit onguardstarter.pas
Procedure OnGuard_Init;
Procedure OnGuard_Stop;
Your old version has onGuard library initialization in every unit
but Typhon IDE load pkgs as static code and
if you build the IDE with OnGuard pkg, OnGuard library start working with Typhon IDE (???)
IDE is the host Application....and this effect Typhon IDE
We moved all onGuard library initialization staff to onguardstarter.pas.
So
-in your applications start you must call OnGuard_Init and
-in the termination of your applications you must call OnGuard_Stop
please try and report
Codetyphon - pl_onguard runtime error 11 years 3 months ago #7025
  • Hector S Ponce
When I write the code in my project in this order
Application.Initialize;
Application.CreateForm(Tformmain1, formmain1);
OnGuard_Init;
Application.Run;
OnGuard_Stop;
the application runs with no errors, so I will use the latest version.
thanks.
Codetyphon - pl_onguard runtime error 11 years 3 months ago #7026
Thanks Sir,
this is an lab task for Lab CT 5.30 :
-Task32 pl_OnGuard, Update, test and fix (Total Steps 3) info
We remove and "version" property....
Codetyphon - pl_onguard runtime error 11 years 2 months ago #7280
  • Shaun
  • Shaun's Avatar
So I guess my WMI implementation was picked up then? I only noticed this thread by accident.
So much more has been fixed in the OnGuard package since then (6 months ago)
Last edit: by Shaun.
Codetyphon - pl_onguard runtime error 11 years 2 months ago #7281
Yes Sir
and we fix many things in the pl_OnGuard package
Codetyphon - pl_onguard runtime error 11 years 2 months ago #7283
  • Shaun
  • Shaun's Avatar
Is there a diff of those changes? An online repository, perhaps?
Codetyphon - pl_onguard runtime error 11 years 2 months ago #7286
Here Sir
