VirtualTree5.2.1 Package 11 years 8 months ago #6651
  • Dinko
  • Dinko's Avatar Topic Author
  • Thank you received: 5
I have application that use pl_virtualtrees package.
I tried to compile this application with CT32-5.20 for windows but target is win64.
CT32-5.10 and all prior versions are able to successfully compile this and all other my application but new version reports an error.
Compiling package pl_virtualtrees 5.2.1: Exit code 1, Errors: 1
Error: Illegal processor type "x86_64-Rintel"
Note: If I start CT64-5.20 then I'm able to compile same application.
Can you help me with that problem.
In attachment you can find simple application that shows the problem. Just choose win64 target for compile.
Regards, Dinko
VirtualTree5.2.1 Package 11 years 8 months ago #6652
did you build win32 to win64 FPC cross build element?
VirtualTree5.2.1 Package 11 years 8 months ago #6654
  • Dinko
Yes. I made FPC build cross element ALL which include Win64.
Today I build specifically Win64 and tried again.
I got the same result with same error message
Regards, Dinko
VirtualTree5.2.1 Package 11 years 7 months ago #6792
  • evgeniy
  • evgeniy's Avatar
I have this error too.
Last edit: by evgeniy.
VirtualTree5.2.1 Package 11 years 7 months ago #6793
  • evgeniy
  • evgeniy's Avatar
It's worked. Change settings for Assembler style from Intel to Default
VirtualTree5.2.1 Package 11 years 7 months ago #6797
  • Dinko
Thanks for solution. I will skip this version of CodeTyphon and wait for 5.30 to test it.
I have some more issues which are not solved (regarding Indy Components, and some more Postgres DB FMTBcd issues)
Regards, Dinko
