Error in component Kgrid (CT 4.92 Win32) 12 years 2 months ago #5790
  • Ramon Retamar
  • Ramon Retamar's Avatar Topic Author
Hi.
I have a error when try to using the kgrid component. I test with a blank application (one test form)...when try to put the kgrid component from kcontrolls pallete, obtain the error:
"Error crating component; TKgrid"
Resource "KGRID_CURSOR_HRESIZE" not found.
And can't use the control. It don't appear on form. In Linux (Mageia Linux 4.0 32 bits) the ide shows the same error message.
Steps:
1) Create a new project
2) Try to drop a kgrid component into empty form
3) This cause a error.
The CT version is 4.92 running in Windows XP 32 bits and Mageia Linux 4.0 32 bits. I don't find other problems with it in both operatins systems.
Any ideas ? :)
Last edit: by Ramon Retamar.
Error in component Kgrid (CT 4.92 Win32) 12 years 2 months ago #5791
Try pl_KControls ver 1.6 from LAB CT 5.00
please report here
The following user(s) said Thank You: Ramon Retamar
Error in component Kgrid (CT 4.92 Win32) 12 years 2 months ago #5794
  • Ramon Retamar
The fix work OK.
Thanks !!!
Now can use the kcontrols components. Kgrid is a excellent multi-purpose grid with a lot of great features.
