Problem with function "AnsiReplaceText" 13 years 3 months ago #4355
  • sam
  • sam's Avatar Topic Author
the method "AnsiReplaceText" does not work. ( with Typhon 4.4 r42002 FPC 2.7.1 i386-win32-win32/win64)
Run the following example code an then compare the text-files.
EDIT: FProjectName:string; is in private-section of TForm
  _tempList:TStringList;
  FProjectName:='project1';
  _tempList:=TStringList.create;
  try
    _tempList.add('\gen\com\pascal\lcltest');
    _tempList.savetofile('before_ansireplacetext.txt');
    _tempList.Text := AnsiReplaceText(_tempList.Text, 'com\pascal\lcltest','com\pascal\'+ FProjectName);
    _tempList.savetofile('after_ansireplacetext.txt');
  finally
    _tempList.free;
I also tried with Lazarus 1.0.10 r41613 FPC 2.6.2 i386-win32-win32/win64. It' works.
Last edit: by sam.
Problem with function "AnsiReplaceText" 13 years 3 months ago #4356
We will check this
Problem with function "AnsiReplaceText" 13 years 2 months ago #4388
  • sam
I have reported this issue now in the FPC Bugtracker.
Report #24853
The problem seems to be even worse. It's not a problem of "AnsiReplaceText". It look's like something messed up in fpc 2.7.1 with Variable's defined inside the class and later on initialized inside a method.
