LazSolutions / LazWebSolutions 14 years 5 months ago #2088
  • acoliveira
  • acoliveira's Avatar Topic Author
mr. sternas, sorry for my poor english.
can you integrate with LazSolutions/LazWebSolutions "github.com/silvioprog/lazsolutions"/"htt...prog/lazwebsolutions"
very samples, using synapse(smtp/http,etc), using geoip and others.
Re: LazSolutions / LazWebSolutions 14 years 5 months ago #2089
we will test and add to CT
soon the lab results
LazSolutions / LazWebSolutions 12 years 4 months ago #5585
  • Fabio Luis Girardi
  • Fabio Luis Girardi's Avatar
  • Thank you received: 13
Mr. Sternas!!
I'm trying built a project that uses pl_LazSolutions and pl_ZeosDBO to arm-linux target (CT 4.8 Linux 64 host), but I can't build my project due some errors on both packages. The errors on pl_ZeosDBO I fixed it on the ZeosLib svn repository on rev 3104, but another developer reverted it in revision 3124 (I don't know why). I'll investigate why my changes are reverted on ZeosLib.
The issue with pl_LazSolutions is on pl_Synaser that don't compiles when a arm-linux target is selected. I did a small workaround for now, to build and test my project.
If I can help, please tell-me...
Last edit: by Fabio Luis Girardi.
