tplColorProgress 6 months 1 week ago #19546
  • Jan Roza's Avatar Topic Author
tplColorProgress is missing a visible property, could that be added?
My application uses a progressbar which will only be visible if an operation with progress is running, so I hide it until the operation is started and hide it again when the operation is finished.
Testing some more I see the property is there when coding but it is missing only from the object inspector.
Could you also add it to the object inspector properties?
Last edit: by Jan Roza.
tplColorProgress 6 months 1 week ago #19547
Yes My Friend.
- Replace with New fixed
- Build pkg
- Re-Build TyphonIDE
The following user(s) said Thank You: Jan Roza
