Bug concerning auto listing the parameters after a period 1 year 4 months ago #19027
  • W. Peterson
  • W. Peterson 's Avatar Topic Author
Windows 10
I wanted to try to stop the yellow suggestion box that pops up when you hover the cursor over an instruction.  I went to the Lazarus site to ask how this could be done because I knew that Lazarus was part of CodeTyphon.
I was directed to go to menu Tools (actually Settings in CT), Options, Codetools, Identifier Completion, and there uncheck 'Automatically invoke after point'.  This wasn't what I wanted, and it stopped the ability to get a list of
options after typing in a period after an instruction (like Memo1.).  So I went back and Re-check 'Automatically invoke after point'.  Unfortunately, re-checking this didn't bring this option back, but from then on it no longer
'Automatically invoke after point'.  The cursor flashes 5 times and then just stays on.  I installed the latest CodeTyphon 8.7 and that didn't fix the problem either, even though I didn't do a test by un-checking 'Automatically
I installed Lazarus to see if it had the same problem, but it reinstated 'Automatically invoke after point' after it was un-checked and re-checked.
My CodeTyphon parameters are below:
Last edit: by W. Peterson .
Bug concerning auto listing the parameters after a period 1 year 4 months ago #19028
  • Thank you received: 230
We will try to fix this
Bug concerning auto listing the parameters after a period 1 year 4 months ago #19029
  • W. Peterson
Thanks.  Something that I also lost was when I click on 'begin', it no longer encircles the corresponding 'end'.  I was able to get everything back into working order by restoring from a backup the (CodeTyphon 8.6) C:\codetyphon\ and C:\Users\User\AppData\Roaming\typhon64\ folders.
Bug concerning auto listing the parameters after a period 1 year 4 months ago #19030
