Self made components packgage problem 2 years 2 months ago #18548
  • Roman
  • Roman's Avatar Topic Author
Hi!
I created my own components package and used them for a long time. Then I changed the components package: I deleted one of the components. But after rebuilding the CT, an error message constantly appears mentioning the missing component! It is impossible to remove the package from the build CT, no matter how I try to do it!
What do you advise in this situation?
Last edit: by Roman.
Self made components packgage problem 2 years 2 months ago #18549
  • Thank you received: 230
Did you check if TyphonStart load the old TyphonIDE ?
a) Delete ALL *exe from
C:\codetyphon\typhon\
folder
b) Rebuild TyphonIDE
The following user(s) said Thank You: Roman
Self made components packgage problem 1 year 11 months ago #18651
  • Roman
I figured out the reasons for the problem described.
It is clearly related to an error in the Code Typhon IDE.
If the project is opened by clicking on the *.сtpr file, then after opening the IDE, the rebuild to install the package never ends with restarting the IDE! The IDE closes after compilation, but does not start automatically. And if you start the IDE manually, the package is not installed.
In order for the package to install normally, you must open the IDE by clicking on the shortcut, and not the associated project file!
