Big Decimal 3 years 6 months ago #17686
  • sleepybird
  • sleepybird's Avatar Topic Author
Sir any big Decimal and big number library available in Codetyphon ?
Big Decimal 3 years 6 months ago #17688
  • Thank you received: 236
Please look at:
bs_Engines pkg
codetyphon\typhon\components\BaseEngines\Math\
Do you have any suggestion ?
Big Decimal 3 years 6 months ago #17689
  • sleepybird
github.com/SicroAtGit/PB-CodeArchiv-Rebi.../Math/BigDecimal.pbi
github.com/rvelthuis/DelphiBigNumbers
and ofcourse   python4delphi
In Math module you suggested the return value are type of longint double single but a data type for currency base 10 is required. If Codetyphon have some base 10 big Decimal library then it can save some poors who calculate alot after Decimal point.
Big Decimal 3 years 6 months ago #17690
We will try to port your suggestion(s).
Big Decimal 3 years 6 months ago #17691
  • sleepybird
Thanks.
