cannot load project with 7.3 5 years 8 months ago #15650
  • Horst Krewett
  • Horst Krewett's Avatar Topic Author
i cannot load an older project with 7.3. The project could load and run in 6.8. After loading with 7.3 the IDE crash without any messages. It seems that the problem must be around the .frm-files or the designer. Even a rebuild of the IDE has not changed anything. This concerns all older projects with some database components espacially ZeosDB, RX and Reports.
Thanks.
cannot load project with 7.3 5 years 8 months ago #15652
My suggestion is to use CTCenter tool  more info
cannot load project with 7.3 5 years 8 months ago #15653
  • Daniel Jaeger
  • Daniel Jaeger's Avatar
Hello Horst
A few months ago I had a similar problem on an older test project. After a comparison with a new project, I found out that there was no widht and height information in the frm-file. After adding the two statements manually, everything went as expected.
Daniel
cannot load project with 7.3 5 years 8 months ago #15654
we have the same problem with projects convert from old Delphi versions
