Codetyphon 7.00 TImage stops working 6 years 8 months ago #14448
  • Raúl
  • Raúl's Avatar Topic Author
I have just upgraded from 6.90 to 7.00 and all images in my forms have dissapeared. I've tried also with a new project, I add a Timage component and eventhough appears in the IDE, when I compile and run image is empty (even its property enabled and visible are true)
regards
Codetyphon 7.00 TImage stops working 6 years 8 months ago #14449
  • Raúl
If I quit the IDE and reload the project I get the following error and the image appears empty in the IDE:
Codetyphon 7.00 TImage stops working 6 years 8 months ago #14450
  • Raúl
Images from my previous 6.90 forms and projects appear empty. :-/
Codetyphon 7.00 TImage stops working 6 years 8 months ago #14451
Please Sir
give us more info
-Your OS
-Did you have other FreePascal installations
-etc
Codetyphon 7.00 TImage stops working 6 years 8 months ago #14461
  • Raúl
Solved!
The Lazarus 2.0.6 I had installed before was messing with CodeTyphon's installation. Solution was to remove Lazarus/fpc and then proceed to install CodeTyphon.
(Windows 10)
Codetyphon 7.00 TImage stops working 6 years 8 months ago #14462
