The problem with multi-project 6 years 9 months ago #14310
  • Roman
  • Roman's Avatar Topic Author
Code-Typhon studio incorrectly processes multi-projects.
1) If you open a regular project ("primary" project), and then open a multi-project and selectively compile the elements of a multi-project, then i18n processing takes place according to the project settings of the "primary" project, and not according to the individual project-setting of the multi-project element. To create .pot and .po files the name of the "primary" project is used, and not the one that is currently compiling. As a result, the localization of the “primary” project deteriorates.
2) When starting Code-Typhon studio, the multi-project opened in the previous session does not automatically open.
Last edit: by Roman.
The problem with multi-project 6 years 9 months ago #14312
your CT Version ?
The problem with multi-project 6 years 9 months ago #14313
  • Roman
Sternas Stefanos wrote: Thanks Sir
your CT Version ?
:) 7.00
The problem with multi-project 6 years 9 months ago #14314
We will try to fix this
