Help With fpCEF3 7 years 1 week ago #14035
  • Victor Vasilevsky
  • Victor Vasilevsky's Avatar Topic Author
Dear colleagues
Please help me, I can’t understand why the component is not installed:
1. I first worked on Lazarus FPC 3.0.4 worked with the fpCEF3 component everything was fine, but I really liked CodeTyphon because of its simplicity and logic
But when I switched to CT 6.90, I could not install the fpCEF3 component
gives an error message
I attach you the file fpCEF3.zip
maybe you can help me sort out the problem
Help With fpCEF3 7 years 1 week ago #14040
Sir my suggestion is to
use pl_CEF4Typhon, Typhon package
fpCEF3 and many other Lazarus packages are out of date
Help With fpCEF3 7 years 1 week ago #14044
  • Victor Vasilevsky
Sir Thank you for your reply,
But the fact is that in CEF4Typhon other components I need one component that would integrate both the window and all the events, so organized in CEF3.
My task is to call the window Cromium.Load ('URL ...') and to support java call
I looked at a bunch of examples, but they do not compile with me; linux swears on windows.
If you send an example for the win32-i386, windows-x64, linux-i386, linux-32.64 platform I will be very grateful to you
Help With fpCEF3 7 years 1 week ago #14046
go to CodeOcean
C:\codetyphon\CodeOcean\pl_CEF4Typhon\samples
we have more than 20 samples for pl_CEF4Typhon package
Help With fpCEF3 7 years 1 week ago #14056
  • Victor Vasilevsky
1. Chose the first example for CEF4Typhon from CodeOcean
2. Created i386_Linux build mode
2.1. Mounted the library .. \ .. \ .. \ .. \ binLibraries \ i386-linux
3. Installed the target platform
4. pointed out gtk2
5. Throws an error
6. Replaced i386 with x86_x64 The error is gone
8 but when compiling again produces errors
I don’t know what to do help
Help With fpCEF3 7 years 1 week ago #14057
  • Victor Vasilevsky
On Windows all working, but not working another OS (Linux_i386, Linux_x86_x64)
Help With fpCEF3 7 years 1 week ago #14059
Yes we working to fix and Linux platform
but you have the latest CEF ...
Help With fpCEF3 7 years 1 week ago #14061
  • Victor Vasilevsky
On latest wersion CEF4Typhon not working, not compiling too (Linux)
Help With fpCEF3 7 years 1 week ago #14062
  • Victor Vasilevsky
Send my please Example With compilinf wrom windows Typhon to linux i386, x86-x64 and running on linux i386 and x86-x6x
ASAP need
Help With fpCEF3 7 years 1 week ago #14063
  • Victor Vasilevsky
In which directory should I put CEF4Client on linux platform
Help With fpCEF3 7 years 1 week ago #14064
For more info
please look
Here OR
Here
