1 Suggestion and 1 question 17 years 9 months ago #5
  • Blaise Bernier
  • Blaise Bernier's Avatar Topic Author
Hi! First of all, thanks a lot for this bundle. I was about tu cry because I could not compile Lazarus with GTK2 on Ubuntu 8.10. It also fixed a lot of bugs I was encountering with some units that could not be found, etc.
Now, a suggestion! I suggest adding ACS (audio component suite) to the distribution. It seems to be a great package and I think it can be nice to use along with GLScene or Graphic 32, etc. It gives you complete control over the audio of yopur computer and it's cross platform.
And here is my question: ACS, seems to be compilable only with FPC 2.2.2. There is still a problem with 2.31 wich makes me ask you how to 'downgrade' cleanly the FPC version given with Code Typhoon. I'm not a Linux pro and I'm a little lost when it comes to manage packages and softwares efficiently.
Thanks a lot,
Blaise
Re:1 Suggestion and 1 question 17 years 9 months ago #6
We will try to add ACS (audio component suite) to CodeTyphon->CodeOcean.
If you want to use FPC 2.2.2 with CodeTyphon
simple change CodeTyphon-binZips-fpc_src.zip
with the additional source from FPC 2.2.2
please use the same file name.
fpc_src.zip has only the latest SVN FPC Source (trunk)
For PilotLogic Sternas Stefanos.
