ENoWideStringSupport 7 years 6 months ago #13352
  • Md. Shariful Alam Khan
I am trying to make one Linux 64bit application using CT 6.5. On my application I used TDataset.locate method, once the application reached the line it raised an exception with the following message:
This binary has no string conversion support compiled in.
Recompile the application with a unit that installs a unicodestring manager in the program uses clause.
Exception at 000000000042722A: ENoWideStringSupport:
Widestring manager not available. Recompile program with appropriate manager.
My application will run in CentOS 6 64bit.
How to resolve can anyone please help?
ENoWideStringSupport 7 years 6 months ago #13353
first please install or upgrade your CT to latest version 6.80,
we have make so many changes...
If the problem exist
we are here
ENoWideStringSupport 7 years 6 months ago #13354
On Windows, I used CT 6.80 without any issue. I cross-compile Win32-Linux64 using CT 6.80. In Linux, I got the exception but in Windows no exception.
ENoWideStringSupport 7 years 6 months ago #13355
My suggestion is
not to use Widestrings on UNIX OSes
Or attach source from your project for more analysis
we want more info to help...
ENoWideStringSupport 7 years 6 months ago #13356
Please see attached pas file. On Execute method's of the class, it runs fine until compareDelta method is called. On compareDelta call I got the exception. Also FYI, I didn't use any WideString. I used memds unit for using TMemoryDataset. What I have in the dataset is a blob field I need that because I am inserting a whole row of a CSV file on to the dataset which is a very big string.
ENoWideStringSupport 7 years 6 months ago #13357
I gave the pas file that I used but yet to receive any response. Please help.
ENoWideStringSupport 7 years 6 months ago #13358
Sorry Sir
but we can't find the problem
ENoWideStringSupport 7 years 6 months ago #13359
I solved the problem by adding LazUnicode unit.
ENoWideStringSupport 7 years 6 months ago #13360
